diverjerR
Jan 05, 2023Aspirant
Want to change Network Password on N750 and connect to my extender which is a N300 Model
I currently have a N750 Model WNDR4300V2 and a N300 Model EX2700 extender, and all works well. Has worked well for years. However, some people in the family wants me to change the password to make ...
- Jan 05, 2023
Yes Laptop and android both can get to the Extender, the screen looks different than video, but haven't done factory reset. better wait until tomorrow as people watching TV.
Jan 05, 2023Guru - Experienced User
factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
- diverjerRJan 05, 2023Aspirant
My PC doesn't have any wireless connection. Maybe I set up the network with Android tablet. Then again maybe I used my laptop when I first set up that is wireless.
But I don't believe I can get to extender from PC. Don't find any wifi connection manager on PC.
Thanks, will go find laptop and see if it finds the extender.
There is a WPS button on main router, but for some reason I have never used that, seems someone told me to do it manually?
- plemansJan 05, 2023Guru - Experienced User
You can try setting it up using the wps button. If it doesn't work, then factory reset and use the assistant.
You can use the assistant by hardwiring your pc into the extender for setup
