diverjerR
Jan 06, 2023Aspirant
Want to change Network Password on N750 and connect to my extender which is a N300 Model
I currently have a N750 Model WNDR4300V2 and a N300 Model EX2700 extender, and all works well. Has worked well for years. However, some people in the family wants me to change the password to make ...
- Jan 06, 2023
Yes Laptop and android both can get to the Extender, the screen looks different than video, but haven't done factory reset. better wait until tomorrow as people watching TV.
diverjerR
There is a WPS button on main router, but for some reason I have never used that, seems someone told me to do it manually?
diverjerR
- diverjerRJan 06, 2023Aspirant
By hand wiring you mean just use a RJ14 Ethernet cable? But it looks like I can use laptop or Tablet. Thanks for your help. Seems Netgear should let me logon extender and change SSID and/or network password without factor reset. Most likely hardware was not designed for them to code those functions.
