sirromdraw1
Jul 17, 2023Aspirant
Want to replace my Nighthawk X10 router with a longer range wifi router
I have a 3 year old Nighthawk X10 router for my home, barn (300 feet away) and dock (150 feet away). I have two Netgear extenders in both the barn and dock. This has worked pretty well for 3 years ...
- Jul 17, 2023
sirromdraw1 wrote:
,,, it sounds like you are saying Netgear has not produced a router with a stronger signal in the past 3 years than my current Nighthawk X10?
Power and throughput is limited by regulations, not by newer technologies and standards like AX. Time for the inconvenient ... a good Hilti cam help.
Jul 17, 2023Guru - Experienced User
For that distance, to get good wireless and performance, point to point would be recommended. Most household routers, even good ones, 300feet is out side of wifi router coverage in distances. To get something across this distance, point to point could work. Something similar to this could work: https://www.netgear.com/support/product/wbc502
Best would be ethernet.
sirromdraw1
Thank you for your quick reply but as I posted I can't run ethernet easily (20' wide concrete driveway between house and barn) and I prefer not to install point to point (very inconvenient to run ethernet cord from router, through walls, up to attic and to outside wall as well as getting power to the unit). So, back to my question, it sounds like you are saying Netgear has not produced a router with a stronger signal in the past 3 years than my current Nighthawk X10?
- FURRYe38Jul 17, 2023Guru - Experienced User
Can try any router and see. Most home class routers wifi range won't cover that range. If they do, wouldn't be great signal.
- schumakuJul 17, 2023Guru - Experienced User
