Steve_in_Mass
Sep 03, 2020Aspirant
WAP - Need to run Wire from Comcast modem/router/AP to a wired WAP
So at work we use Cisco Waps that allow roaming laptops to connect tothem depending on the best signal of the nearest WAP on the network. I want to run cat5 to WAPs (with power packs /not w PPoE) ...
Steve_in_Mass
Sep 14, 2020Aspirant
Do you have any model numbers I should look at.. All I see are wireless APs.. I want these to be hard wired APs for best presormance on my property.
schumaku
Sep 15, 2020Guru - Experienced User
An Access Point (as offered by the leading brands) is always a Wireless Access Point with at least one Ethernet (Gigabit, MultiGig) for the wired network connection handling the connection to the in-house network, to the router, to a PoE switch connecting to the network by copper or fiber again.
Some WAP have additional capabilities for example to link up wirelessly to another WAP. This is not the typical deployment for a WAP however.
Here an example of two Wireless Access Points - one wired (the WAP540), one connected by a wireless link (the WAC564) extending also to a local wired network/devices.
- MusicalChickSep 17, 2020Initiate
schumaku wrote:An Access Point (as offered by the leading brands) is always a Wireless Access Point with at least one Ethernet (Gigabit, MultiGig) for the wired network connection handling the connection to the in-house network, to the router, to a PoE switch connecting to the network by copper or fiber again.
Some WAP have additional capabilities for example to link up wirelessly to another WAP. This is not the typical deployment for a WAP however.Here an example of two Wireless Access Points - one wired (the WAP540), one connected by a wireless link (the WAC564) extending also to a local wired network/devices.
Very good explanation. Thanks for your article
