geneeckhart
Mar 02, 2021Tutor
WAP or WAP2 support for AC1750 WiFi Mesh Extender
Can I get this Extender to support WAP or WAP2 or am I stuck with WEP?
- Mar 03, 2021
geneeckhart wrote:Thanks. The manual is telling me that if my router (Comcast) is using WAP2, that the extender can't connect to it. Is there another way that I'm missing?---How are you attempting to install it? Using wps or the installation assistant? Try using the installation assistant.
what comcast router is it?
Also, I didn't understand what this meant? CM2000-> RAX200-> GS716v2-> EX8000---its just my signature with what my current setup is.
Mar 02, 2021Guru - Experienced User
the ex6250 supports wpa2
geneeckhart
Mar 02, 2021Tutor
- plemansMar 03, 2021Guru - Experienced User
