1rustyrig
Jul 06, 2021Initiate
WAP over Ethernet
 I have a Nighthawk R7800 that is providing WiFi to the ground floor of my home.  The router is located in a room where all the RJ45 terminate for the entire house making it easy to extend via CAT6.  ...
- Jul 06, 2021
Yes, you would.
But many devices will roam between a router and an AP without to much issues. Some older ones can be a bit sticky (not roam as fast or until signal drops).
So is it worth it to upgrade to a full mesh system?
Maybe.
Since you've got the hardwired capability, the benefit is that you don't need the more expensive triband mesh systems since you're using the wired backhaul. Tends to make it a bit cheaper.
Will it outperform your R7800? Thats another question.
The R7800 is one of best AC routers netgear makes (imo).
You need a decent AX router and phone/tablet device to be faster than it.
You could always go:
R7800---->mesh setup in AP mode (using different ssid/wireless channels).
That'd allow you the speed of the r7800 in its vicinity with mesh coverage for those devices that roam.
1rustyrig
I'd like to have the mesh characteristics. I'm guessing that will require an upgrade to my existing R7800 'core' router?
Jul 06, 2021Guru - Experienced User
Yes, you would.
Maybe.
