goblea
Nov 17, 2020Star
WBC502 Airbridge
I have purchased a WBC502 to connect my garage to my home internet where I want to attach a small network switch to connect 4-5 devices. I only have one WBC502 and was thinking setup as an AP. Does ...
Nov 17, 2020Guru - Experienced User
Do you have an ethernet line ran from your home to the garage?
Or are you just seeing if you can get the WBC to reach the garage?
Because in point to point mode, you'd need 2 of them.
did you look through the manual? page 11 goes over the modes and page 111 goes over how to change/manage it in that mode.
https://www.netgear.com/support/product/wbc502.aspx
goblea
Nov 17, 2020Star
No cable currently using Orbi but keeps on dropping so thought this would be a better option. The website states that this can be done, might be in Client Bridge mode though.
Just seems very hard to setup but if your right its not going to work for me, i have attached a screen shot of the website showing a WBC talking to a router
