adidasgirl75
Jun 23, 2026Follower
We desperately need an extender at home for work.
This may be a silly question, but do you remember how you got your Netgear extender to connect to the Gryphon? We desperately need an extender at home for work. So far, we can't get them to work. đ Getting desperate because it's putting us behind. Thank you for any help.
What method of setup are you using?
What error are you getting?
What actual router model are you installing it to?
Did you try using the installation assistant for install?
What extender are you installing?
What extender are you installing?Also,
- are you connecting the extender to the Gryphon's ethernet? Or are you wanting to connect it to the Gryphon's wifi?
- is the goal to get the wifi to reach the home office? Or is there a different goal?
