PeterTheSbam
Nov 09, 2016Aspirant
Web-based authentication for Ex 3700
I bought an EX3700 to log into the Telstra Air network (same as the FON network). The network requires browser-based authentication, where you log in with a username and password at a web page (like...
- Nov 11, 2016
Hello PeterThesbam
The Ex3700 will not work with this type of network if it needs to use a web based login it can only connect via SSID and password or WPS. And no information on if this will be possible in the future.
DarrenM
DarrenM
Nov 11, 2016Sr. NETGEAR Moderator
Hello PeterThesbam
DarrenM
- PeterTheSbamNov 11, 2016Aspirant
Thanks for your help.
- PeterTheSbamNov 17, 2016Aspirant
Hi Darren,
Do you know if any Netgear range extenders are capable of web-based authentication?
Peter.
- DarrenMNov 22, 2016Sr. NETGEAR Moderator
Hello PetertheSbam
We have 1 extender that does do that the PR2000 all others do not.
DarrenM
- PeterTheSbamNov 22, 2016Aspirant
Thanks Darren,
Unfortunately that model's no longer sold in Australia. Will keep looking.
Peter.
