Dustin_V
Jun 12, 2018NETGEAR Employee Retired
We've unlocked the potential of our WiFi Extenders by adding WiFi Mesh!
Our latest firmware update allows users of our EX6400 and EX7300 extenders to enjoy the benefits of WiFi Mesh! With a single WiFi Network Name and Smart Roaming, you can create a whole hom...
ozzcaddy
Oct 14, 2018Aspirant
I had already downloaded the latest Firmware for my EX7000 extender, but never opened up its capabilities. Yesterday I setup FASTLANE and selected Option 2.4MHz between router and modem and 5GHz bteween router and device, and checked ONE NAME.
I use a laptop which both the laptop and modem/EX7000 are turned off overnight. When I turn both on, under the ONE NAME option my laptop is connecting to the modem at 2.4GHz. Once I disconnect from the network and reconnect, I then connect at 5GHz and eveything is great.
What causes me to have to disconnect and reconnect to access the 5GHz network of the EX7000? Or should I reset the router and not check the ONE NAME box and manually add another SSID for the 5GHz?
Thank you.
