khalidm3
Jan 27, 2011Aspirant
Wg 602 v4
I purchased WG 602 V4 NetGear Access point. I can not log in to configuration menu. Please explain its log in and configuration. I want to catch it WLAN and release WLAN. Is it possible? Is it ...
jmizoguchi
Jan 27, 2011Virtuoso
PC and WG must be connected each other first.
see manual to WG602. it will tell you how to access and setup the unit
if you have speedtouch modem without router in place not sure how you are going to setup? you can only use SINGLE device if speedtouch is not modem/router combo unit
