khalidm3
Jan 27, 2011Aspirant
Wg 602 v4
I purchased WG 602 V4 NetGear Access point. I can not log in to configuration menu. Please explain its log in and configuration. I want to catch it WLAN and release WLAN. Is it possible? Is it ...
Kendo2
Feb 26, 2013Aspirant
If it is set up as an Access Point and DHCP is enabled, your router has probably issued it an IP address. Moreover, without a complete factory default reset, you probably cannot access the 602 using Netgear's recommended IP settings or methods. A hard factory reset will clear out any custom settings, which may not be desired. Also, the 602 may not show up as a client in you router DHCP client tables, but if the router can communicate with it, you can too. My router begins handing out addresses at 192.168.1.100. I see devices listed from .101 to .104. I used the ping command (ping 192.168.1.100) and got a response from 192.168.1.100, so I typed "http://192.168.1.100/" into my Browser and got the username (default) admin password (default) password or login page = success. No login = factory reset. You must find out the IP address that the router or other DHCP enabled device issued the WG-602. Lastly, a picture(s) screen shots of your custom settings -- if applicable -- may save a lot of time.
