readering
Apr 20, 2012Aspirant
WG102 - Access
I am trying to connect to a Netgear WG102 to set it up. I have reset following the instructions to turn off, power on and hold the reset button for 5+ seconds. I have connected a PC directly t...
jmizoguchi
Apr 20, 2012Virtuoso
google angry ip scanner and check the range of IP to see if destination IP is correct.
in some model I remember it was not same as manual and/or reset the unit as well too
