readering
Apr 20, 2012Aspirant
WG102 - Access
I am trying to connect to a Netgear WG102 to set it up. I have reset following the instructions to turn off, power on and hold the reset button for 5+ seconds. I have connected a PC directly t...
fordem
May 01, 2012Mentor
A rapidly flashing LAN light would suggest a connection problem of some sort - on other devices I have seen this caused by duplex setting mismatches, try changing the duplex settings on the PC and see what effect it has.
