Platypus2
Sep 10, 2013Aspirant
WG102 AP and iOS 6
I seem to be having DNS issues with any devices running iOS 6 when connecting to a WG102 AP. The router's (Draytek Vigor2830n) wireless works fine, however when connecting a device to the WG102 th...
Platypus2
jmizoguchi wrote: Have you try putting public dns on iphone (wifi setting) using ios6?
Hi, thanks for helping.
Yes I have just tried that now, no change, still wont work.
I did try turning security off and funnily enough it seems to work. Now that isnt a solution for me, but it hints and what the problem might be. Was there not an issue late last year with ios 6 and netgear products? ios 6.1 allow me to connect to the AP but it seems that the issues haven't completely disappeared as its still struggling.
What I have so far;
ios 5 works flawlessly
No security works flawlessly
With security, ios 6 will 'eventually' work, and thats the best I can describe it, I have no idea why it suddenly starts working. I just browse around the LAN for a bit till it seems to 'start' working :S - I thought this might be down to AES as I had WPA and WPA2 setting on, but after just having WPA on with TKIP the same issue is still present.
