fredrikhemma
Oct 15, 2011Aspirant
WG103 Bridging
Hello!
I'm having trouble with bridging of two WG103.
I get a couple of pings to go through but most of the time i doesn't work. If I reset the devices and reconfigures them it works until I restart one of the devices. The lateset firmware in both devices. I have tried to go on different channels without luck.
Any ideas or do I have to buy something else that works better?
Best regards //Fredrik
Config as follows:
Device 1:
IP: 192.168.1.10
Sub: 255.255.255.0
Gateway: 192.168.1.1
DNS1: 192.168.1.1
Wireless mode: 11bg
Broadcast SSID: Yes
Channel: 6
Data Rate: Best
Output Power: Full
Bridging and repeating enabled.
MAC Adress of device 2 wlan interface in settings.
Profile Name: NETGEAR-WDS-1
Network Authentication: Open System
Data Encryption: None
Device 2:
IP: 192.168.1.11
Sub: 255.255.255.0
DNS1: 192.168.1.1
Wireless mode: 11bg
Broadcast SSID: Yes
Channel: 6
Data Rate: Best
Output Power: Full
MAC Adress of device 1 wlan interface in settings.
Config as follows:
Device 1:
IP: 192.168.1.10
Sub: 255.255.255.0
DNS1: 192.168.1.1
Wireless mode: 11bg
Broadcast SSID: Yes
Channel: 6
Data Rate: Best
Output Power: Full
Device 2:
IP: 192.168.1.11
Sub: 255.255.255.0
DNS1: 192.168.1.1
Wireless mode: 11bg
Broadcast SSID: Yes
Channel: 6
Data Rate: Best
Output Power: Full
- jmizoguchiVirtuosotrying using different channel 6, 11
- fredrikhemmaAspirantThank you for answering. I have already tried that with the same result. Everything looks fine until one of the ap's get rebooted. Then nothing and the only thing that helps is factory reset.
I will never ever again recommend any netgear wireless products. From now on Cisco is the only thing I will work with. You really get what you pay for. - jmizoguchiVirtuosodoes the unit function stable if you use as AP?
