  • Did you have any look finding the later firmware version? Ill contact support for it now but I need it for setting 16 of them up with a wms5316.
    Riich
  • I found that version 2.0.37 has a bug on Point-To-Point links. It configures fine but does not reconnect after a reboot. And to make things worse V2.0.25 seems to have a bug of dropping a packet every 7-10 Seconds. Have done some extensive testing on PTP connections and have not found a solid solution for the problem. 2.0.37 gives a stable connection but after a reboot connection does not re-establish. Currently running with 2.0.25 as it at least gives me some sort of connectivity.
    Anyone that has a solution for this? Yes I even bought a 3rd WG103 to make sure it is not hardware. Definitely a FW issue.:mad:
