finluxa
Sep 21, 2011Aspirant
WG302v2 - DHCP server - can't set gateway
I need to use the Access Point to issue IP's (DHCP mode). The DHCP client is disabled in this mode. The wired network point is connected to a router. However, if I assign the routers IP address, the u...
jmizoguchi
Sep 22, 2011Virtuoso
you need to use different subnet on WG to dish out IP for client
looks like 192.168.1.x is your primary so if you want DHCP on AP then use 192.168.2.x
