finluxa's avatar
finluxa
WG302v2 - DHCP server - can't set gateway
I need to use the Access Point to issue IP's (DHCP mode). The DHCP client is disabled in this mode. The wired network point is connected to a router. However, if I assign the routers IP address, the u...
