finluxa
Sep 21, 2011Aspirant
WG302v2 - DHCP server - can't set gateway
I need to use the Access Point to issue IP's (DHCP mode). The DHCP client is disabled in this mode. The wired network point is connected to a router. However, if I assign the routers IP address, the u...
PaonQC
Oct 12, 2011Aspirant
Thanks 4 replying but is it normal that I get an error message that this ip is not on the same subnet?
