Shadeclan
Sep 17, 2013Aspirant
WG602v3 Login Problem
I had my WAP connected to a WinXP machine and, with a little difficulty, was able to log into it and set up security. I recently converted over to Kubuntu - I'm running v13.04. I was able to get the...
Shadeclan
Sep 26, 2013Aspirant
jmizoguchi wrote: Assume dhcp on 2nd and AP device ip on same LAN subnet?
Fixed it! I set the NIC facing the WAP on "manual" and gave it an IP address of 192.168.0.226. Doing so allowed me to log into the WAP but prevented access thru the Linux box to the internet. I changed the WAP IP address to the max IP address of the subnet being assigned by my ISP to the facing NIC when it was set to "shared". I then set the NIC back to "shared" and volia!
Thanks for putting me on the proper trail!:D
