CaboSteve
May 31, 2013Aspirant
WG602V3 Not Visible on network
WG602 connected via Netgear Power Line Adapters to modem/router as follows: MODEM/ROUTER>>>NG PA>>>NG PA>>>SWITCH>>>WG602V3 Ip scanner software on XP PC connected to MODEM/ROUTER cannot see WG60...
jmizoguchi
Jun 01, 2013Virtuoso
Reason I ask is because I cannot access WG602 over network to configure using "netgearXXXXXX" and since I have no idea what ip the DHCP has assigned, I cannot access it directly either.
Poor setup... You should have assign static IP outside of your DHCP range.
You best best is hook AP to main router and find it and fix that.
other issues with power line with traffic is somewhat common that you loose what you are saying but internet works. I have seen even mine to print on my network printer behind the power line from main network in the past.
