CaboSteve
May 31, 2013Aspirant
WG602V3 Not Visible on network
WG602 connected via Netgear Power Line Adapters to modem/router as follows: MODEM/ROUTER>>>NG PA>>>NG PA>>>SWITCH>>>WG602V3 Ip scanner software on XP PC connected to MODEM/ROUTER cannot see WG60...
CaboSteve
Jun 02, 2013Aspirant
Success - knew I should not have shortcutted the fixed ip addy! Setting fixed ip outside of DHCP range now makes WG602 visible to network. Thanks for tip.:o
