harvonkeuka
Sep 24, 2013Aspirant
WG602v4 No Internet With Time Warner Cable Modem
Like many other posts, was working, stopped working. Not knowing how someone else set it up way back when, I reset the WG602 to factory defaults. Cable modem is fine. I plug in laptop via ethernet ...
jmizoguchi
Sep 25, 2013Virtuoso
You can try by setup static ip on wg602 with private ip , setup witelss etc
Connect to cable mode
You might able to get ip from ISP to sigle laptop
