npoe25
Sep 16, 2010Aspirant
wg602v4 setup
Ok im trying to do the setup procees tht came with the instructions... I get to step 2a and it says enter 192.168.0.227 and i do but nothing happens! It talks about changing the static ip address and...
Daedalus01
Aug 14, 2011Aspirant
hitting the reset pin for a second or so usually doesn't wipe out the NVRAM, you usually have to hold it, and i recommend anywhere from 30-90 seconds.
