bridge
Dec 08, 2011Aspirant
wgr614 and d-link dap-1522
I have had a wgr614 v7 for quite sometime (connected by wire to a pc, another ethernet client). I also use my laptop and iphone as a wireless clients.
All has been well until I got a d-link dap-1522 to create a wireless bridge to connect a dish network set-top box and a lg blu-ray player. Setup was not too difficult and the connections worked fine. But I found that after sometime, the wireless network would not work!!!
For example, I get back home and my iphone that had got disconnected would not connect so is the case with the bridge and my laptop.
What I know is that as soon as I make any change to the setting on the wgr614, and it forces the router to re-start, everything works like a charm!! Same if I disconnect power and re-start. All this time, no issue (as you might guess) with the wired connection from this router.
Any help would be greatly appreciated.
- jmizoguchiVirtuoso
details why you are doing - bridgeAspirant
jmizoguchi wrote: details why you are doing
The first time this happened I did not know what else to do to make my iPhone work. Later I just was changing a few settings like wireless channel to see if that would help. - jmizoguchiVirtuosoWGR614 is connected to satellite and dlink is bridge correct?
- bridgeAspirant
jmizoguchi wrote: WGR614 is connected to satellite and dlink is bridge correct?
WGR614 is connected to dsl modem and dlink is bridge. - jmizoguchiVirtuosookay
I would look channel interference issues with surrounding wireless SSID is around you
