bugg
Dec 19, 2011Aspirant
WGR614 DHCP Login Problem
Hi Everyone, i recently bought a new Netgear WGR614 wifi router. I'm currently using a ISP provider which requires login everytime(atleast once in some time if i dont logout) i need to use Internet. ...
bugg
Dec 20, 2011Aspirant
jmizoguchi wrote: that is will not going for with ANY router... that is accessing the portal
So...You mean i cannot get through this Problem in Any way? Here's the Problem it Created among it's subscribers.
BTW, Did you see the screenshot that i've linked above?
Thanks, I Guess the Prob cannot be solved.
