SkipTalker
Sep 09, 2011Novice
WGR614 v6 not working ater power outage
I'm one of the millions that lost power Thursday in southern CA. To day I find out my Wireless router is no longer working. If I by pass it and go straight from the DSL modem to PC internet works fine...
jmizoguchi
Sep 09, 2011Virtuoso
Bypassing "Netgear Smart Wizard" (This url may behave differently with all the Netgear Router)
http://192.168.0.1/basicsetting.htm
http://www.routerlogin.com/CA_HiddenPage.htm
These option may not work on some routers. If you still get "Netgear Smart Wizard", please follow the wizzard.
try bypass and try to re-load firmware and see.
after the firmware flashing, hard reset the router and see if you can correct the issues
