ashu2087
Jul 15, 2013Aspirant
WGR614v10 --> WNR2000RPTv2 --> Access Point??
Hi guys, I need some help with choosing an Access Point which will allow me to extend my wireless range (through LAN) using WPA-PSK2 security. My current set-up is Broadband into the WGR614v10 whic...
ashu2087
Hi,
Thanks for the reply. I know both of these are not access points but I posted in this forum so that someone could recommend an access point for me based on the configuration I have mentioned above.
Can I connect a new WNR2000RPT to the existing one trough LAN and use the internet wirelessly on the new one? Because I need to place it outside the wireless range of the existing WNR2000RPT, hence need to connect with a LAN cable.
If not, which AP can I use to connect my existing RPT over LAN?
