rtfarley
Oct 21, 2011Aspirant
WGR614v6 cannot connect two PC's
After relocating and returning to Comcast I can only have one PC connected to my router at a time. If I connect two, using cables, the router goes into a check cycle showing all indicator lites, then ...
bastialex0825
Oct 21, 2011Novice
Check if your computers IP are set to static.
Check also on your router if "use router as DHCP server" box is checked.
