rtfarley
Oct 21, 2011Aspirant
WGR614v6 cannot connect two PC's
After relocating and returning to Comcast I can only have one PC connected to my router at a time. If I connect two, using cables, the router goes into a check cycle showing all indicator lites, then ...
rtfarley
Oct 23, 2011Aspirant
Are there any settings in Windows that could be causing a conflict? I recall having connectivity issues in Arizona (different ISP) and the man who lived nearby made some changes to the settings. I don't remember what he did though. Could have been to the static IP settings.
It is strange that when I plug in the cable for the second computer and the router goes into the cyclic check, the network status shows a cable is disconnected, ok, then disconnected as the router cycles.
Anyway, if you think a new router is needed, so be it.
Thanks to all for the help.
