Eldrod
May 26, 2020Tutor
What Do I need to Replace R6700v3 System?
I have a current setup with a CM1000 ethernet-connected to a R6700v3 (first floor) and connecting wirelessly to an EX7000 (third floor). The second floor seems to be spotty, so I wanted to upgrade t...
- May 26, 2020Much better performance using the cm1000 versus the orbi with integrated modem. Definitely keep your cm1000. It's a solid modem
May 26, 2020Guru - Experienced User
If you're planning on buying another router and another extender, I'd just skip it and go directly to a full mesh system like orbi. The mesh extenders work well but they don't work that great when you have more than 1. Reason why nothing is controlling it. with orbi, its got the router controlling the system. plus you can add satellites to it as needed.
And by the time you buy a new router and the ex8000, you're basically in the price range for the rbk43 or rbk53 system.
Eldrod
May 26, 2020Tutor
Thanks! I'll check into Orbi as I've not looked into it before. Also, while my existing system supports mesh, I don't actually use it since the firmware on the router (post v1.0.2.62_10.0.46) didn't ever seem to work. After getting burned with flaky firmware updates, I just stayed on that version. I would prefer to have a working mesh, however. Does Orbi do that?
