Eldrod
May 26, 2020Tutor
What Do I need to Replace R6700v3 System?
I have a current setup with a CM1000 ethernet-connected to a R6700v3 (first floor) and connecting wirelessly to an EX7000 (third floor). The second floor seems to be spotty, so I wanted to upgrade t...
- May 26, 2020Much better performance using the cm1000 versus the orbi with integrated modem. Definitely keep your cm1000. It's a solid modem
Eldrod
May 26, 2020Tutor
I'm looking at the RBK50 as a complete replacement, but I need a cable modem. Is there a cable version of the Orbi Router AC3000 (RBK50) or can I just connect the router to my existing CM1000 modem? Any performance cons to that idea?
May 26, 2020Guru - Experienced User
- EldrodMay 31, 2020Tutor
Excellent suggestions for the Orbi RBS50. I replaced the Nighthawk with the Orbi and now I have a much faster home network with a mesh that actually work. Thanks!
