moniela
Feb 26, 2022Tutor
What is the best solution for Wi-Fi Extender from the main home to a wooden shed?
Hi, I have a router sitting in the lounge of my house and a Netgear wifi booster extender AC1900 in my Kitchen. From the Kitchen I now need to extend the wifi signal to a garden wooden bulding ap...
moniela
Feb 26, 2022Tutor
Hi,
Thank you so much for your reply.
Currently I am using a Netgear AC1900 which is positioned in the kitchen but of course this isn’t enough to reach the garden shed which distance is approx 20 metres from the kitchen.
If I upgrade as you suggested, what would it be the best triband mesh system to go for? And should I plug that in directly in the shed or should it be plugged nearer to the router but the actual range will reach the garden shed?
Many thanks!
Many thanks!
Feb 26, 2022Guru - Experienced User
1. AC1900 is a speed. not a model.
2. the shed is a challenge. 20 meters isn't that far of a distance. the problem is that the exterior of homes tends to block signals very well. this happens because they're made from materials that have components to them that block signal. things that block: foil lined insulation, metal siding, concrete, brick, concrete board, etc. Same with sheds. they tend to be made from metal and metal blocks wifi signals.
the best thing for you to try is to get a short extension cord and connect the extender to it and prop the extender up in a window. (glass doesn't block wifi). Then go outside to the shed (both right outside it and inside it) and test if you can get a connection to the extender and test the actual speed you get (speedtest app).
that'll tell you both if a extender/satellite could get a signal to the shed and if that signal will pass through into the shed. Its your best hope for testing before buying anything. If it can reach but not get into the shed because of the material its made from, then you might have to look at a different option like burying an underground ethernet wire.
- monielaFeb 26, 2022TutorModel number EX6410-100UKS
what would it be a stronger extender that I could purchase.
I will try what you suggested but I think that a stronger ranger extender will be needed.
Thank you- plemansFeb 26, 2022Guru - Experienced User
there isn't really "stronger" wifi extenders.
The broadcast strength is set by the governing body (fcc in the US).
And its been maxed out for quite a while.
so you aren't really going to get any extra range because there's isn't really a stronger one.
