RouterBeast22
Jan 08, 2023Aspirant
What is the best WiFi extender to use with AX5 5 Stream AX4200 Wifi Router (RAX43)
michaelkenward
Jan 08, 2023Guru - Experienced User
There is never any "best". It all depends on what is going on at your end, what you need, and how much you want to spend.
You might like to provide a bit more detail and not cram everything into the subject.
This is a good place to start.
WiFi Boosters & Extenders | Wifi Range Extenders | NETGEAR
Try plugging your needs into the filters on the product pages.
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
A better place to ask for help in extenders might be in the section where people talk about extenders.
RouterBeast22
Jan 17, 2023Aspirant
Thank for your advise. I checked out the link for
but now I am still a bit confused and undecided. The WiFi 6 Extenders that are only dual band or the WiFi 5 Extenders that are Tri Band. The WiFi 6 has the latest technology, but less range. The Wifi 5 have better range but are older tech. The Wifi 5 with Tri Band does sound like the dedicated connection to the router is better, but again the Wifi 5 tech is older and less capable.
Would you have any recommendations based on the router I have?
Thanks!
- michaelkenwardJan 18, 2023Guru - Experienced User
Do you have any wifi clients that can use WiFi 6?
