ArizonaJim
Dec 13, 2016Tutor
What is the technical difference between extenders ex6120 and ex6920
What is the technical difference between the ac1200 ex6120 and ex6920 extenders? I purchased ex6920's yet Netgear Geine says there ex6120's?
ArizonaJim
Dec 15, 2016Tutor
Darren...also the netgear genie recognizes the ex6920 as a EX6120
DarrenM
Dec 15, 2016Sr. NETGEAR Moderator
Hello ArizonaJim
That is because it is a ex6120 are you having a issue with the setup?
DarrenM
- ArizonaJimDec 15, 2016Tutor
Hello Darren, Ya I'm getting the same answer, To me Netgear is misleading it's customer base to use a model# implying your getting the latest device and not just a packaging of 2 model ex6120's. Thanks
