spikerz
Apr 28, 2014Aspirant
What should i buy ?!?
Hi to all, I've two houses. I should bring internet in the second house. In my first house i've a modem router DG834G v3. Very soon it will come a R7000. Now the problem, i don't know what i'...
spikerz
Apr 29, 2014Aspirant
What product do you recommend to buy ?!?
I've the R7000 such as router in first house. I can't connect any external antenna to R7000 in the first house, so i can use only the external antenna in the second house.
But what instruments i have to buy to take the wifi signal from the first house ?!?
Access point or range extender ?!?
Is it better to buy it with 2.4 or 5 GHz band?!?
I would like take advantage of the same speed as the R7000.
Thanks a lot.
Thanks a lot.
