spikerz
Apr 28, 2014Aspirant
What should i buy ?!?
Hi to all, I've two houses. I should bring internet in the second house. In my first house i've a modem router DG834G v3. Very soon it will come a R7000. Now the problem, i don't know what i'...
jmizoguchi
May 02, 2014Virtuoso
Oh.. Well you will only setup by no security but able to use 802.11ac setting to have WG to connect via repeater setup may fail
I would say you need 802.11ac extender
This seething you need to buy and test see
Otherwise running cable is on horizon. I assume power circuit is separate so power lime device can not be used.
I would also search 802.11 extender that has external antenna capable
