Dirlligaf
Aug 16, 2016Follower
What would be a better solution? Getting the Nighthawk Routers or a Nighthawk Extender?
Hi All, I have Verizon FiOs with 150/150 for speeds. My upstairs room is hit or miss with the WiFi signal, but I did get a Netgear Powerline adapter to turn my electrical outlet into a network...
DarrenM
Aug 18, 2016Sr. NETGEAR Moderator
Hello Dirligaf
If you extend your network using wireless you are going to get slower speeds compared to running Ethernet or using powerline. Did you set your R6300 to be a AP? also have you made sure you have the latest firmware on the router.
DarrenM
