Claudemarc
Mar 08, 2020Follower
Where do I find the password to connect to NETGEAR_EXT
to be able to use the app Nighthawk.
To activate the app it tells me to use the NETGEAR_EXT but I have no password to do so??
Thanks
Thanks
1 Reply
ThanksThe netgear_ext is the default login info. It should be on the label for the device or be open for setup. Did you look on the label?
Otherwise the ex6250 has an ethernet port you can hardwire into for setup. it tends to go smoother/faster this route
