CGab1972's avatar
CGab1972
Which extender can i use with my Netgear Nighthawk D7000
Good afternoon all,
i have a nighthawk D7000 and want to add either extenders or mesh, if so what would you recommend. previous experience appreciated
regards
Carl
  • StephenB's avatar
    Can you tell us a bit more about the space you are trying to cover with WiFi now, the router location, and where the dead spots are?
    • CGab1972's avatar
      CGab1972
      So, the netgear nighthawk is in the lounge and I get dead spot on the ground floor and first floor away, areas which are not in the same vercinity as the router. I have bought a netgear nighthawk x45 range extender? But it doesn’t really seem to be cutting the mustard ?
      • StephenB's avatar
        I think you must mean the X4S (the EX7500).  That is a good match for the D7000.  What issues are you seeing with it?
        You do need to place the extender in an area where you have a solid connection to the router (generally somewhere between the router and the dead spot you are wanting to cover).
