sharee3's avatar
sharee3
Follower
Mar 29, 2016
Which Extender Do I Purchase for N900 Router
Hi. Im very confused abou which WiFi Extender I should purchase for the N900 Wireless Dual Band Gigabit Router. I know the maximum mbs is 900. Right now I have freqency channel set to 450mbs each.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello sharee3
    It all just depends on your budget what is the space you need to get more wifi signal to how far away is that space from the router?
    DarrenM
