mtebor's avatar
mtebor
which extender to purchase?
Even though I have a small house, my router is in basement and I am having weak connections going through brick for outside use.
I am looking for a wireless extender recommendation that is compatible with this router.
Thanks
  • plemans's avatar
    Thanks
    that "going through brick" is the issue right there. Wifi struggles with brick. Its excellent at blocking wifi signals. If you're needing wifi outdoors your options come down to:
    1. put a device in a window so it'll broadcast through the glass.
    2. run an ethernet wire outdoors and connect something like the WBC502 running in access point mode
    3. run a powerline device with wifi adapter to get it outdoors. They're not outdoor rated so you'd have to setup your own protective setup for it.
    • mtebor's avatar
      mtebor
      Thanks for the recommendation.
      Because it is a video doorbell that is giving me the issue, I could put the extender near a window.  I am just wondering which extender/mesh would work best and is compatable with my current router (purchased 9 months ago)
      • plemans's avatar
        Not sure which router you purchased but most extenders are compatible.
        Are you putting the extender outdoors then? On the inside of the glass?
        reason I ask is most video doorbells are right up against the brick and if the extender is indoors, its not going to be line of sight for the doorbell.
        Same with many that you place outdoors. to hit the doorbell without the brick in the way, you'll want pretty much line of sight on that doorbell or it'll cause issues.
        Sorry brick/concrete are a PITA.
