Danmancalif
Jan 18, 2016Aspirant
Which is better: Netgear AC750 vs WNDR4300 set up as repeater
I currently have a Netgear WNDR4300 router installed upstairs in a two-story house. Using iPhone 4S phones downstairs on the Wi-Fi network I'm experiencing lots of dropouts from the Wi-Fi connection. ...
TheEther
Jan 18, 2016Guru
The WNDR4300 will not function well as a repeater, so you should go for an extender. The iPhone 4S can only do 2.4 GHz, so an AC750 (2.4 GHz and 5 GHz) extender would be overkill. But if you have other Wi-Fi devices that are dual-band, then they would benefit.
