newuser4820
Apr 08, 2020Tutor
WHich method is best?
We just purchased the Nighthawk X6S 8000 and have constant trouble with the extender just dropping off. Originally I used the same SSID as our existing home wireless router. After the NH 8000 continu...
- Apr 17, 2020
Its not known for playing friendly with extenders. See:
newuser4820
Apr 17, 2020Tutor
AT&T Uverse 5268AC FXN Label also note "Pace"
Apr 17, 2020Guru - Experienced User
- newuser4820Apr 19, 2020Tutor
Accessed the Pace router, found DHCP setting and changed hours from 24 default to 999. We'll see how this goes ... Thank you.
- plemansApr 19, 2020Guru - Experienced User
Let us know how it goes. We see many pace routers complaining of this issue.
