ahebert's avatar
ahebert
Which range extender works best with eh AC1900 Nighthawk, model R700 router?Thanks
I'd like to get a range extender that will get the signal from inside my home to a building about 100 or so feet away.
There are several on Amazon, but which would work best with the R700 AC1900 Nighthawk?
Thanks so much.
  • Hello ahebert
    Any AC model will work fine with the R7000 just up to you on price and specs you are looking for.
    DarrenM
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello ahebert
    DarrenM
    • ahebert's avatar
      ahebert
      Thanks so very much. I ended up moving about 4 feet and all of a sudden the signal reaches 100 feet right where I was hoping it would. This is a super router.
      Thanks again,
      Al
      • Driver8666's avatar
        Driver8666
        Tutor
        I use an EX6200 Repeater (Extender) coupled up with the R7000 and zero issues.
