caseyjanke's avatar
caseyjanke
Follower
Feb 14, 2017
Which WAP for use with R6220
I recently installed a R6220. What I'm looking to add now is a couple of WAP's. Given the following requirements, what is the best WAP for the job:
1. I will wire the WAP's to the router (or a switch connected to the router).
2. I want to use the same SSID's and passwords on the WAP's as is on the router.
3. I would like it to be POE, but not a requirement.
4. I want the clients be able to move around the entire building without having to change SSID's or re-enter passwords.
Thanks!
