jmb3810
Sep 04, 2018Aspirant
Which wi-fi extender works with AT&T
I need to get a wi-fi extender. Which is the best to get for an AT&T uverse aaris NVG589. Thanks
Sep 05, 2018Guru - Experienced User
Thanks
This is an N300 router (single band, 802.11N). A WN3000RP would work (and is the same speed as your router).
Can you give us some more info on what you are thinking of doing -
- If you are trying to cover a dead spot?
- If you are wanting to provide ethernet for a device that has no wifi?
- Something else?
Either way, how far away is the spot you are trying to reach, and what obstacles are there between that spot and the router?
- jmb3810Sep 05, 2018AspirantI installed a Kuna security light and it needs a wi-fi signal. The signal gets very weak when it reaches the front door from the back of the house.
- StephenBSep 05, 2018Guru - Experienced User
jmb3810 wrote:
I installed a Kuna security light and it needs a wi-fi signal. The signal gets very weak when it reaches the front door from the back of the house.Sounds like the WN3000RP would be reasonable then. Place the extender towards the front of the house (close enough to the router to get a good connection to it, but also close enough to the Kuna to reach it).
- jmb3810Sep 05, 2018AspirantThanks so much!
