jmb3810
Sep 04, 2018Aspirant
Which wi-fi extender works with AT&T
I need to get a wi-fi extender. Which is the best to get for an AT&T uverse aaris NVG589. Thanks
jmb3810
Sep 05, 2018Aspirant
I installed a Kuna security light and it needs a wi-fi signal. The signal gets very weak when it reaches the front door from the back of the house.
Sep 05, 2018Guru - Experienced User
Sounds like the WN3000RP would be reasonable then. Place the extender towards the front of the house (close enough to the router to get a good connection to it, but also close enough to the Kuna to reach it).
- jmb3810Sep 05, 2018AspirantThanks so much!
