paulshaw's avatar
paulshaw
Follower
Jul 26, 2019
which wifi booster to get
hi,
i live i a snall prpoerty and wondered witch wifi booster was base to purchase, ive seen ex6100 but this doenst have an ethernet port, will i even need one once ive got a booster blugged in?
Thanks
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    It depends if you need to connect a device via a wired connection in the location you are putting the extender. IF not then you should be fine with the ex6100.
    DarrenM
